Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Join Date
    May 2001
    Posts
    176
    Tornado Alley
    L5740HSTC
    Default Kubota Factory Top N Tilt worth it?
    Is the top n tilt offered on new kubotas a quality item? I'm thinking of getting one since it's in stock at a local dealer and I get instant gratification.
  2. #2
    Veteran Member brain55's Avatar
    Join Date
    Jan 2008
    Posts
    1,824
    Brentwood, CA
    Default
    It used to be that the cylinders offered in kubota factory kits were Gannon cylinders, which are very good quality.
    Brian
  3. #3
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,912
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Kubota Factory Top N Tilt worth it?
    Mine seem to be but so does Fit Rite and I am sure others. I got mine as part of the package and got a decent discount or so it seemed.
  4. #4
    Join Date
    May 2001
    Posts
    176
    Tornado Alley
    L5740HSTC
    I know I could save some with a Fit Rite and a few others. It's just nice to get something right away so you can put it to use rather than order and wait. I just want to make sure I don't spend an extra $200 and regret it.
  5. #5
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,412
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    I doubt that Gannon is making the "TnT" sets for kubota any longer since Gannon is long gone and it is my understanding that Woods who I believe has also sold out, no longer builds them either.
    The Kubota units seem to be a good unit. The one problem that I have seen with them is that they use some of the side links built for a certain size, say a bigger Grand L series tractor on the next frame size down and while it physically fits, you will not get an equal amount of tilt to each side as it should be. If you happen to have the tractor that the side link was designed for, then your good to go, but if you have the next size down, then while it will work, it is not really the right unit for that machine.
    Something to check on or at least ask about before you get that almost instant gratification.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  6. #6
    Join Date
    May 2001
    Posts
    176
    Tornado Alley
    L5740HSTC
    I suspect if the side link was sized wrong, you could just put the adjustable on the other side and dial it in, assuming you didn't have to move it too far. Thanks for the replies everyone. I feel better about getting it.
  7. #7
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,412
    Quote Originally Posted by JamesKubota View Post
    (This is what I always recommend to get it right on)
    The one that I happen to see was about 2" too long. That is a long way to adjust the link down. You loose a lot of lift. Yes it can be done, or the other thing is to use different pin hole locations in the clevis.
    Whatever works.
    Brian
  8. #8
    Join Date
    Jul 2012
    Posts
    117
    Dewey, AZ
    Kubota B7800
    When I install top n tilt kits, I always move to manual adjustable link to the left side while installing the tilt cylinder on the right side.
    Mike
    B7800 "Drowned Rat"
    It spent 6 weeks under water
  9. #9
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    IIRC correctly the tnt for the L40 fits a L10, L30, MX4700 and 5100.I adjusted my manual side link a few turns so I have a equal amount of movement.
  10. #10
    Super Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    8,301
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD LTR166 Lawn Tractor
    How about a mini TnT for a BX?
Similar Threads
  1. New Kubota Factory
    By MessickFarmEqu in forum Kubota Owning/Operating
    Last Post: 03-04-2014, 09:52 PM
  2. Kubota factory finish
    By GonHuntin in forum Kubota Owning/Operating
    Last Post: 10-18-2012, 03:07 AM
  3. Top-N-Tilt as a Factory Option?
    By Glenn9643 in forum Massey Ferguson Owning/Operating
    Last Post: 03-06-2004, 09:15 PM
  4. Kubota Factory Rebates
    By glennmac in forum Kubota Buying/Pricing
    Last Post: 09-15-2001, 11:23 PM
  5. Kubota Factory Rep?
    By PaulT in forum Kubota Owning/Operating
    Last Post: 06-13-2001, 11:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
