Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Apr 2013
    Posts
    50
    Default 3 pt hitch assembly
    Anyone have a picture if their 3 point hitch? Mine is still sitting in the box because there are no instructions. I'm not perfectly clear on the assembly, but if I at least had a picture I could put it together then I am sure. Bought my new BX25 about three months ago and haven't needed the hitch yet, but wanted to assemble it at least. Thanks for any help/advice.
  2. #2
    Join Date
    Oct 2007
    Posts
    70
    Durango Colorado
    BX23
    Default Re: 3 pt hitch assembly
    I had the same problem last week so I stopped by the dealer and took some pics. Here they are.3 pt hitch assembly-imag0631-jpg3 pt hitch assembly-imag0635-jpg
  3. #3
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    8,805
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Remember Messicks will promptly email you diagrams.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  4. #4
    Join Date
    Apr 2013
    Posts
    50
    Default
    Thanks. Pictures are worth a thousand words!
  5. #5
    New Member
    Join Date
    May 2009
    Posts
    13
    sNH
    BX25D
    I installed mine finally this past weekend to make sure I knew how. Not sure why they used rings and cotter pins instead of clips in a couple of places. If you don't get instructions, pm me
  6. #6
    Join Date
    Apr 2013
    Posts
    50
    Default
    Quote Originally Posted by jjk58 View Post
    Thanks. I'll probably tackle it this coming weekend.
  7. #7
    Join Date
    Oct 2011
    Posts
    2,203
    Olalla WA, Kitsap Peninsula, West of Seattle
    Kubota BX25
    What did you do with your operators manual? It is all explained in there. If your dealer did not give you yours, shame on them. Its on page 43.
    Ron
  8. #8
    Join Date
    Apr 2013
    Posts
    50
    Default
    Quote Originally Posted by Tractor Seabee View Post
    Ron
    Well I'll be...there it is on page 43. Guess I figured it wouldn't be in there since it was an option and doesn't come with the tractor. Kind of like the MMM had its own manual. My bad! Thanks for the info.
  9. #9
    Join Date
    Oct 2011
    Posts
    2,203
    Kubota BX25
    That manual is only a pile of paper unless you know what is in it. Take the time to browse and learn your resource. I know I am preaching But!
    Ron
  10. #10
    New Member
    Join Date
    May 2009
    Posts
    13
    sNH
    BX25D
    I'm going to stop by the dealer this weekend but anyone have any pointers for simple draw bars? Is a stabilizer important?
    the manual shows 24in between mount pts. but an online web search doesn't show much out there... simple meaning holes for a couple lawn tractor type pull-behind (sweeper and aerator) that use a pin and for attaching a chain to pull stuff...
    thanx
    joe
Similar Threads
  1. 3 Point Hitch assembly for MF 1010 or Simplicity 9518 ?
    By Fairview in forum Parts/Repairs
    Last Post: 07-23-2012, 01:35 PM
  2. Assembly Info for 3-Point hitch - X485
    By JohnnyTractor in forum John Deere Lawn & Garden
    Last Post: 02-08-2012, 04:42 PM
  3. Kubota L2072 Quick Hitch Plow and hitch assembly
    By WayneB in forum Wanted Ads
    Last Post: 11-27-2011, 06:07 PM
  4. Help with L2180 Quick Hitch Assembly
    By moship in forum Kubota Owning/Operating
    Last Post: 01-28-2011, 09:47 PM
  5. bx2660 quick hitch assembly
    By gjock in forum Kubota Owning/Operating
    Last Post: 11-08-2009, 07:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
