I just finished the BX7310 Alternator upgrade to my BX1500. After dealing with Ronnie at tractorsmart.com and my local dealer, Kubota told both of them that the kit was not available for installation on a BX1500. No reason was given for why this was so, but at the advice of Ronnie and my dealer and after reading this thread quite a few times, I proceeded with the upgrade anyway.
I purchased all of the parts separately staring with the Kubota IG-L 40amp 12V alternator I found on ebay (the seller has quite few of these - NEW) for $90. Quite a savings than if I purchase new from the dealer. I then purchased all of the other parts needed from tractorsmart.com. Ronnie helped me identify all the parts needed. Grand total for everything came to $173 (shipping included). If purchased at my dealer, K2561-98620 kit (BX7310) cost $289 plus shipping, so I saved over $100.
I follwed Charliebrn's instructions. The only mod that had to be made was the lower mounting bolt (one that goes through the cast bushing) had to be trimmed by 3/8" as the end of the bolt was about 1/8" from the belt. I assume the cast mount on the BX1500 is a little smaller in thickness than the BX18xx or BX22xx. Also, I did not have a bushing inside the cast mount, as Charliebrn said needed to be removed. Other than that, everything else matched to a 'T'!
To ease my mind, I did not connect the charging lead to the alternator, as I wanted to test the output first. I fired up the BX1500, put my meter on the alternator, and whalaa, 17.2VDC, which is within the spec of the Desno alternator.
One last thing, as was mentioned in this post, my wiring harness kit did not come with the red rubber insulating boot or nut for the output lug on the alternator, as was mentioned in a previous thread. tractorsmart.com is tracking this down for me. Thank you Charliebrn, and updates by Electron8 and RichT.
Now, onto adding the lights!!!
