Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,878
    Kansas...USA
    Kubota B2620 , Case 448
    Default B 2620 HST/Hydraulic Fluid Change
    Okay so I tried the "Search Function". Forget that. In draining the HST filter oil outlet and the Hydraulic filter oil outlet, I get only 2 gallons. The book specifies the capacity as 4 gallons. So I looked for the other elusive drain plugs in the rear end. Let's see??? It looks like most of the bolts are holding the rear end together. Since I own a parts manual, I looked there to see if there is any identification of such. The manual show to likely bolts but calls them "flange bolts"...not drain plugs. Well I loosened one on either side and the oil does drain out. So the job is done. But the Owners Manual sure didn't help me much. Can anybody else confirm my expericence or tell me where I went wrong? Thanks.........Mike........Oh Yeah.......watch out for the little steel ball that is spring loaded on the HST side drain plug.
    Kubota B2620 HST (2012) Case 448(1983)
  2. #2
    Platinum Member kcender's Avatar
    Join Date
    Mar 2010
    Posts
    868
    Nova Scotia
    GR2120 B2650 Cab
    Default Re: B 2620 HST/Hydraulic Fluid Change
    I don't have enough hours on my B2620 yet to do the service but thanks for the heads up on the drain plug,good to know.
  3. #3
    Join Date
    Dec 2009
    Posts
    2,878
    Kansas...USA
    Thank you kcender....Surely someone has changed out the HST/Hydraulic fluid on the B2620.....will have to wait and see. I was changing mine early just to see how it goes and because I have been pushing it pretty hard with the mowing and using the FEL ( have 150 hrs on it). And besides, I already had purchased the Super UDT in 2009 when owing the BX, which was traded in 2012 for the B2620. The Super UDT isn't available anymore since the Super UDT "2" came out.
  4. #4
    Gold Member vic4news's Avatar
    Join Date
    May 2007
    Posts
    286
    Merrimack County, NH
    Kubota B3030
    It sounds like you found all the drain plugs. I'm not familiar with the B2620, but on the B2630,B3030 there are three drain plugs. One for the transmission and one on each side of the rear axle housing.
    Vic
  5. #5
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    There should not be any spring loaded steel ball in the drain plug. You must have pulled out something else
    You can tell the drain plug as it is centered between 2 mounting bolts and if you look carefully you will see it only screws into the outer housing and not both inner and outer. It also will have a brass or aluminum washer.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  6. #6
    Join Date
    Dec 2009
    Posts
    2,878
    Kansas...USA
    Thanks kuboman. I just studied the Owner Manual again, and really think I followed it for both the HST and Hydraulic filter drain plugs. I did find the ( one left /one right) axle housing bolts that are for drain purposes when I did the work originally....but they were not all that obvious to me. I took some pictures this morning and hope to struggle through to get them posted.
    I think it was "John Thomas", TBN member, who said that one should be cautious about taking it as gospel from those that don't have the exact same kubota model. For example, I believe it was an Orange Tractor tutorial that talked about a strainer on the B2620. Mine doesn't have a strainer.....at least the manual doesn't say so...and I've never found one.
    Cheers, Mike
  7. #7
    Join Date
    Dec 2009
    Posts
    2,878
    Kansas...USA
    B 2620 HST/Hydraulic Fluid Change-img_0673-jpgB 2620 HST/Hydraulic Fluid Change-img_0673-jpgB 2620 HST/Hydraulic Fluid Change-img_0674-jpgB 2620 HST/Hydraulic Fluid Change-img_0675-jpg Well, it took longer to post these pictures than it did to drain the fluid. Apparently I was not suppose to remove the bolt at the base of the HST filter (the one with the spring and ball). So I stand corrected.....I did not follow the OE manual. Thus it looks like the bolt at the base of the mid PTO (17 mm) and the (12 mm) middle bolt on on either side of the rear axle case are the three that one removes to do a complete fluid drain. Am I stupid, blind or just hard headed. Thanks everybody. Mike
  8. #8
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,131
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    Quote Originally Posted by oldballs View Post
    Thanks for info.
    As you age and millions of bits of data go thru your brain to be processed, stored and or deleted you'll delete/store some good and bad data. When you return to do this job again 2/3/4/5/6 years from now you may have co-mingled/deleted this data. I'd suggest, since I've had this happen a lot and it's getting more frequent the further away I get from July 1947, that you put some white or black or whatever other color paint you have on the heads of the bolts that need to be removed. Looks clean enough now to hold paint.
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 17 Cadillac XT5. 2007 Toyota FJ Cruiser
  9. #9
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    So in your last 2 pictures there is a drain on your mid pto and the other picture the drain is the one between the 2 outer mounting bolts. Both sides are identical.
    L5740 LA854 loader
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    JD317 sold
    JD323D
  10. #10
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    Looks like you found the right ones in the pictures. I believe you are correct that you do not have strainer. I thought my 3200 did not have one too because of the the 2620 I had before but discovered I was wrong with careful investigation and some smarter than me members here.
    L5740 LA854 loader
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    JD317 sold
    JD323D
Similar Threads
  1. When to change hydraulic fluid?
    By varmint in forum Owning/Operating
    Last Post: 09-25-2017, 08:24 PM
  2. hydraulic fluid change
    By lilburr in forum John Deere Owning/Operating
    Last Post: 07-14-2013, 10:47 AM
  3. hydraulic fluid change
    By jtheise4 in forum Parts/Repairs
    Last Post: 04-12-2011, 10:04 AM
  4. Hydraulic fluid change?
    By bdunegan in forum Grey Market Tractors
    Last Post: 11-16-2007, 09:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
