Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,096
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Default Re: BX Tie-Rod boot ripped (partnumbers PLEASE?)
    Mine have been torn off and gone for 8yrs/2000hrs. Idly worrying about it has been effective so far.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  2. #12
    Join Date
    Mar 2002
    Posts
    1,107
    N.E. PA
    BX22
    Quote Originally Posted by Tollster View Post
    Include me as well, tore mine last month, BX23. I would like to see the boot protector techman, sounds like a great idea, can you get us a picture?
    Here is a picture of the tie rod end with the boot cover.
    Paul
    Attached Thumbnails Attached Thumbnails BX Tie-Rod boot ripped-boot-cover-jpg
  3. #13
    Veteran Member Tollster's Avatar
    Join Date
    Feb 2005
    Posts
    1,452
    Benton, Pennsylvania
    Kubota, BX23
    Nice Job, thank you Techman!
    Kubota BX-23, BH, FEL, MMM, Various Bro-tek attachments, Exmark Lazermark.
    ASME Certified welding inspector specializing in Visual, Mag Particle, Dye Penetrant, and Ultrasonics
  4. #14
    New Member
    Join Date
    Feb 2013
    Posts
    18
    Southern AZ
    Kubota BX 25
    Quote Originally Posted by SPYDERLK View Post
    larry
    I noticed my boots were cracked a bit but I'm probably going to go this route. If I have to replace the whole thing, then I'll wait until one breaks or stops moving. Until then, if it works it works and there's no real need for me to mess with it.
  5. #15
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,096
    VA
    Quote Originally Posted by Shett View Post
    It may be worse to leave the boot on after it is breached. It might hold water and keep it wet. Im rather surprised that mine show absolutely no ill effect from running open. If I were to guess Id predict 10,000 hrs to wear out/fail.
    larry
    This side of 40
  6. #16
    Join Date
    Aug 2011
    Posts
    959
    Tauranga NZ
    Kubota BX2350
    Quote Originally Posted by rich bx View Post
    Thanks, Just ordered two, lets see what I get..
    How did you get on ???
    Did it fit ? and were you able to use the included clips ??
  7. #17
    New Member
    Join Date
    May 2011
    Posts
    4
    Kubota BX2200
    When mine split, I cleaned it up good with brake cleaner an applied some "Goop" repair in a tube. Let it set up for 24 hours and it's been fine for nearly a year now.
  8. #18
    Join Date
    Feb 2005
    Posts
    1,452
    Kubota, BX23
    I have not given it a good look and it is currently over on my property, but curious if those of you that have been up close and personal if you believe I could tap a Zerk fitting in somewhere and forget replacing the boot?
  9. #19
    Platinum Member tjkubota93's Avatar
    Join Date
    Mar 2013
    Posts
    653
    Arlington, TN
    Kubota bx1860
    Default
    I did the same on my truck. They were split on the ball joints when I got it. I cleaned with brake kleen and put black rtv on cracks
  10. #20
    Elite Member Sodo's Avatar
    Join Date
    Apr 2012
    Posts
    2,899
    Cascade Mtns of WA state
    Kubota B-series & Mini Excavator
    I have not given it a good look.......but curious ......if you believe I could tap a Zerk fitting in somewhere and forget replacing the boot?
    No way. Its an axial ball joint, there is no mild steel 'cap' its all forged steel. Look at the pic at top of the thread. Agreed removing a torn boot altogether is better than one with a rip. It looks crappy and unmaintained but if the boot is gone it looks fine.
    Be careful what you wish for, you might get it.
Similar Threads
  1. Torn BX24 tie rod boot = $47?
    By mpowrd in forum Kubota Owning/Operating
    Last Post: 08-11-2010, 11:19 PM
  2. Tie Rod Dust Boot Proctectors
    By massey driver in forum Customization
    Last Post: 05-28-2010, 10:13 AM
  3. GC2300 tie rod dust boot
    By cdthom in forum Massey Ferguson Owning/Operating
    Last Post: 05-13-2010, 11:38 PM
  4. BX Tie Rod Boot Guard (How to make)
    By lowboy in forum Kubota Owning/Operating
    Last Post: 04-19-2008, 10:23 AM
  5. Torn tie-rod boot on BX
    By gobbler in forum Kubota Owning/Operating
    Last Post: 08-31-2003, 12:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
