Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
  1. #31
    New Member
    Join Date
    Nov 2012
    Posts
    14
    Etters,Pa.
    BX25
    Default Re: BX Tie-Rod boot ripped
    sodo, sorry sir no time to even work on it, things bad right now, all i can say is the part no. is right from bota and bought at messicks off the same diagram.
    anthonyv, good deal there too and cheaper. good to know,thanks.
  2. #32
    Join Date
    Feb 2013
    Posts
    59
    Honeoye Falls, NY
    Kubota BX24
    I bought the K1253-01660 parts for my BX24 from Messicks and installed them today. They are the correct parts and fit perfectly. My boots have been gone since I brush hogged my field this spring and I like to keep things in good shape but the idea of replacing the whole joint just to fix the boot didn't sit well with me. They were relatively easy to replace with the hardest part getting the retaining wire around the boot after getting the boot in place.
  3. #33
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,345
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    I figure I would have spent upwards of $1000 in time and parts keeping my BX in boots over the yrs. Instead, I saved both and did more work with the tractor.
    Its still functioning as well as ever.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  4. #34
    Elite Member
    Join Date
    Sep 2003
    Posts
    4,160
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
    Lost the boots on my L5030 almost 1500 hours ago, joints still in good shape. Parked outside 100% of time. Do more damage replacing them all the time than letting the joint be exposed to weather.
  5. #35
    New Member
    Join Date
    Apr 2011
    Posts
    14
    yanmar 187d
    Cheap soft rubber, poor design! It should have a hard (metal) shield with the joints in such an exposed spot. ATV`s do for CV joints. I think maybe a 1/2 piece
    of 1" conduit clamped over boot would shield it.
  6. #36
    Elite Member Sodo's Avatar
    Join Date
    Apr 2012
    Posts
    2,941
    Cascade Mtns of WA state
    Kubota B-series & Mini Excavator
    This is caused by driving thru sticks and bushes.
    **Any shield** could pretty much eliminate the problem, even a bicycle inner tube over it. From the "HOW-TO" below you can see how easy it is to add a bicycle innertube over the existing boot. Electrical conduit would work too, but design that if it gets bent (jammed into the boot) that it doesn't rip the boot itself.
    Here is a link to a HOW-TO for replacing torn tie-rod boots. It's a fairly easy job, the most difficult part is putting on the spring clamps without ripping the boot. Might be prudent to use zip-ties, and not pulled so tight, to allow the boot to slide off, (instead of rip) if it is being hassled by a stick. I think the spring clamps (if you don't rip the boot during installation) are detrimental to these boots. I sold my BX (with new boots) but if I was keeping it, i think I'd remove the spring clamps and replace with zipties, and not real tight.
    Be careful what you wish for, you might get it.
  7. #37
    New Member
    Join Date
    Feb 2013
    Posts
    14
    South Western PA
    Kubota BX2230d diesel
    My Redneck Boot Cover
    BX Tie-Rod boot ripped-boot-cover-camo-kubota-jpg<a href='http://www.tractorbynet.com/c/kubota' onclick=kubota.jpg  Views: 865  Size: 64.9 KB  ID: 378860" class="thumbnail" style="float:CONFIG" />
    KUBOTA BX2230d Diesel Owner
    60" mower deck
    front end loader
    Murphy's Family Inc., Washington, PA
  8. #38
    Join Date
    Apr 2012
    Posts
    2,941
    Quote Originally Posted by Camo kubota View Post
    Redneck
    Very nice! That ought to do it but what kind of redneck cuts up a new tire?
  9. #39
    Bronze Member rich bx's Avatar
    Join Date
    Jul 2013
    Posts
    59
    Raleigh
    Kubota BX 23
    Quote Originally Posted by Sodo View Post
    Hey Rich bx, what happened with the boots, do they fit?
    Sorry Sodo-
    I haven't been in this board in a while and even worst, I bought those boots, but haven't got around to installing them
  10. #40
    Member
    Join Date
    Mar 2012
    Posts
    39
    NW PA
    NH TC40A
    OK maybe sorta hijacking, (and I did post in another thread about a week ago), but has ANYONE checked the rubber boot on the input shaft of your hydrostatic pump (by the fan)? In addition to my tie rod end boots being rotten, I was under the tractor (BX1870) for the first time last week and noticed that the boot on the driveshaft is rotten as well. BTW I purchased this tractor new in August 13. My dealer said to bring it over, they'd replace 'em...
    So, later in the month or the first part of July, when things have slowed down a bit (at dealer), we'll see....
    Thanks
Similar Threads
  1. Torn BX24 tie rod boot = $47?
    By mpowrd in forum Kubota Owning/Operating
    Last Post: 08-11-2010, 10:19 PM
  2. Tie Rod Dust Boot Proctectors
    By massey driver in forum Customization
    Last Post: 05-28-2010, 09:13 AM
  3. GC2300 tie rod dust boot
    By cdthom in forum Massey Ferguson Owning/Operating
    Last Post: 05-13-2010, 10:38 PM
  4. BX Tie Rod Boot Guard (How to make)
    By lowboy in forum Kubota Owning/Operating
    Last Post: 04-19-2008, 09:23 AM
  5. Torn tie-rod boot on BX
    By gobbler in forum Kubota Owning/Operating
    Last Post: 08-30-2003, 11:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
