Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default Re: Lighting up my B2320
    Good idea. I also have the dynamo, so I'm going to go LED. I think I'll try one forward and one rearward to see if it is enough light. Thanks.
    Quote Originally Posted by dex3361 View Post
    I mounted 4, 27 watt LED lights. 2 mounted forward and 2 mounted backward. I have the low amp dynamo so this was much cheaper than an upgrade and there is great light nearly 360 degrees around. Here is a link to the ones I bought. LEDSTORES
  2. #12
    Join Date
    Mar 2010
    Posts
    135
    SW Michigan
    B 2320
    Quote Originally Posted by AStanton View Post
    I bought this magnetic light from Northern Tool for use on my BX-25. It plugs into your 12-volt accessory port; I believe is was about $40. In the pic, you will see a small pet collar. The magnet is strong. The collar was for added piece of mind.
    I like that idea, nice and simple. Thanks!
  3. #13
    Platinum Member Firefighter Kubota's Avatar
    Join Date
    Aug 2008
    Posts
    685
    Seacoast NH
    Kubota 7510
    Before leds were reasonable I installed 4 55w lights.. and have the 40 amp alt upgrade. I'll probably swap them out this year.
    need great LEDS and great prices.. check out LED Lights, Bulbs & LED Lighting Accessories - SUPER BRIGHT LEDSLighting up my B2320-picture-157-jpgLighting up my B2320-picture-160-jpgLighting up my B2320-picture-161-jpg
    B 7510
    FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 54" Puma 3pt Snowblower w Hydraulic chute controls, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, Stereo, AND A CUP HOLDER!
    IAFF L-2892
  4. #14
    Veteran Member sandyc's Avatar
    Join Date
    Mar 2003
    Posts
    1,396
    Steep Falls, Maine
    Kubota B3350 HSDC
    I bought 2 LED lights from Amazon for about $50 and mounted on ROPS using existing nuts that were welded on ROPS. Used angle irons for shelf brackets and wired up under the left rear fender using switch. Seems to work well.....we'll see when the snow flies if I need more light.
  5. #15
    Join Date
    Mar 2010
    Posts
    135
    SW Michigan
    B 2320
    Quote Originally Posted by sandyc View Post
    Snow's coming soon!! We've had a few flakes here and there, and one 2 to 4" fall so far, I think it's going to be a snowy one...
  6. #16
    Join Date
    Oct 2005
    Posts
    54
    Pine Bush, NY
    Kubota B2630
    I used a piece of white pvc pipe (painted black) and mounted two 27 watt led flood lights to the pvc, then ty rapped it to the ROPS. I also installed 2 switches so I don't drain my battery. On my B2630, there were power leads under the rear right wheel well. I picked up the 27 watt led's on ebay for $26 each. They are really bright.
    Attached Thumbnails Attached Thumbnails Lighting up my B2320-lightbar2-jpg   Lighting up my B2320-lightbar1-jpg
    Joh 14:6 Jesus saith unto him, I am the way, the truth, and the life: no man cometh unto the Father, but by me.
  7. #17
    Join Date
    Mar 2012
    Posts
    64
    South Pittsburg, Tn
    B2920 Kubota, GT275 Deere
    The LEDSTORES add says they are available as a flood or spot light pattern; which do you recomend?
  8. #18
    Join Date
    Aug 2008
    Posts
    685
    Seacoast NH
    Kubota 7510
    Quote Originally Posted by Howard92 View Post
    With lower quality LEDS its often hard to see the real difference in the two but the spots still create a great flood.... where you loose a little penetration with the floods... I'd go spots all the way... doubt you'll even notice much of a difference
    B 7510
    IAFF L-2892
  9. #19
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Here are some cheap light from Northern Tool on my BX. They are floods. I have them set out to the side so I can see to mow in the dark.
Similar Threads
  1. New Lighting
    By NHmitch in forum Iseki
    Last Post: 04-26-2013, 06:45 AM
  2. Need Help lighting for new garage
    By scrivy69 in forum Projects
    Last Post: 09-17-2010, 05:43 PM
  3. lighting
    By todda323 in forum Yanmar
    Last Post: 01-23-2006, 03:58 PM
  4. Lighting
    By al f in forum New Holland Owning/Operating
    Last Post: 12-21-2001, 12:20 PM
  5. Must be the lighting...
    By Muhammad in forum Related Topics
    Last Post: 10-24-2000, 12:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
