Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Member
    Join Date
    May 2011
    Posts
    32
    2012 Kubota M5140DT
    Default Is a 9 Foot Fisher plow too big for my 5140?
    Hello all,
    I bought a 9 foot Fisher plow from a friend and have mounted it to a 3/8 quick attach plate. It seems huge. Did I buy one too big? Anyone with any experience. I will be installing a relief valve.
  2. #2
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Default Re: Is a 9 Foot Fisher plow too big for my 5140?
    Googled it. Ahh...a snow plow. I'll let someone else handle this.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  3. #3
    Veteran Member FatTire's Avatar
    Join Date
    Oct 2007
    Posts
    1,181
    Colorado
    Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
    9 foot is wide for a 5140. But how much snow do you need to move in one shot? Do you use tire chains? If your snow is not too deep/heavy, at least you'll clear a wide path. Try it out and see!
  4. #4
    Elite Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    3,589
    michigan
    jd 1070
    Quote Originally Posted by FatTire View Post
    But if you angle it 45 degrees for best snow moving, it could be too narrow ! I use an 8 footer and on my 1070 and it works very well for me at a 30 degree angle. The 45 angle is best for smoothing, too, if you have dirt or gravel to contend with.
    Make sure you have plenty of front weight for steering control.
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
  5. #5
    Elite Member CobyRupert's Avatar
    Join Date
    Oct 2012
    Posts
    3,547
    Washington County, NY
    JD 5075E
    9 ft angled 45 degrees is clearing a 6'-4" path.
    JD5075E, Frontier RC2084 Rotary Cutter, Wallenstein FX65 Skidding Winch
  6. #6
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,207
    Lakes Region, Maine
    M 9540 Kubota
    They say "plow with the storm". Your first pass will be tough if you let it accumulate, after that you can half blade it. You know each snow is a little different, heavier wetter and under tire conditions as well. I think you'll be fine. If I snooze on a deep one, that is let it get to deep, the first pass is down the milldle with the blade straight. A deep enough snow will push most any plow off direction.
  7. #7
    Join Date
    Feb 2011
    Posts
    870
    Parish NY
    555DTC Farmall 200
    Have ballast too. Our 9 foot 6 plow is close to 1k in weight
  8. #8
    Member
    Join Date
    May 2011
    Posts
    32
    2012 Kubota M5140DT
    I have filled AG tires. I really do not need to move snow very far. My driveway is near a half mile with 5 or so push offs, but it is wide enough to push snow to the side for most winters. I do have a 5 foot snow blower in case we get a wicked winter. Thanks for all the advice. I will post picks when I finish my terrible paint job.
  9. #9
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    4,017
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    I have an eight ft. on my L4240,you should have no problem with a nine.
  10. #10
    Member
    Join Date
    May 2011
    Posts
    32
    2012 Kubota M5140DT
    That's what I wanted to hear, thanks
Similar Threads
  1. Snow Equipment Buying/Pricing 8 foot fisher plow for 5045E
    By vtsnowedin in forum Snow Removal
    Last Post: 10-25-2015, 01:44 AM
  2. mounting a fisher plow on my bx24
    By kubotalinc in forum Customization
    Last Post: 02-12-2014, 01:16 PM
  3. Fisher plow on Satoh question
    By Mike Woodman in forum Hydraulics
    Last Post: 09-07-2010, 04:02 PM
  4. Fisher plow on 1250
    By radioman in forum Massey Ferguson Owning/Operating
    Last Post: 11-27-2008, 06:29 PM
  5. fisher 7-1/2 truck plow on my tractor is DONE
    By papy in forum Build-It Yourself
    Last Post: 01-02-2008, 03:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
