weld on 30mm collar to accept bucket pins etc
   / weld on 30mm collar to accept bucket pins etc #2
Watch they don't distort from the welding process. It might make pin installation difficult.
   / weld on 30mm collar to accept bucket pins etc #3
Princess Auto has them too, a bit cheaper I think... I welded mine 90 degrees at a time, very little distortion.
Sean
   / weld on 30mm collar to accept bucket pins etc #4
It looks like that collar has sufficient wall thickness not to distort, especially if you follow Chilly's advice. Tack it in place and skip weld. Also, since it's not a high speed bushing, you could easily buff out the ID if the pin is too tight.
   / weld on 30mm collar to accept bucket pins etc #5
I use a shaft coupling W/O groove and cut to the length I need. They are a lot heavier and the extra thickness and length helps eliminate any distortion. When welding I run shaft through and align the weldments with each other. I buy them at Amazon in any shaft/pin size I need at the time. Metric also.
Ron
