chilibit
Member
Let me describe the issue and I did try searching.
I descend a long grade to my farm gate, hang a U-turn and yank the hand brake and kill the motor. Gate closed I shift to neutral, start the motor and feed the accelerator and simultaneously release the hand brake. It does not want to move off up the hill. I have owned two 900s and this is not what I think is normal.
Let the foot off accelerator, mash the foot brake (first push is spongy and goes 3/4 to floor and second push is hard and high) then move foot from brake to feed the accelerator and it will engage normally and I motor back up to the top of the ridge.
There are likely two separate issues. A leaking master cylinder perhaps on the mushy pedal side but why does the foot brake activation seem to disengage some kind of transmission lock (loosely used term I know)? How the leaking MC could lose fluid in less than a minute puzzles me. Frankly, I seem to recall that starting off after only using the hand brake was a non-issue in the past.
Any insights appreciated.
Vince
Vince
