3 point hitch broke
   / 3 point hitch broke #1
Locoweed
Gold Member
West Tx.
Kubota B2620
Well, shucks & other comments.
   / 3 point hitch broke #3
Yep, hard to sit on a 2 legged stool.
Well, if it had been just the shaft that had broke, it would not have been too bad. Unfortunately, that is the lesser problem. Seems like a bolt broke that holds the control valve assy. The ear on the other end broke & the control valve dropped into the differential gear assy. & it got drove forward & poked a hole in the gear case. It's 3 years old & 617 hour on it. I guess I'll go have a talk with the dealer Monday & see how much this is going to cost me.
   / 3 point hitch broke #5
Ouch! Best wishes on that one. KTAC?
   / 3 point hitch broke #6
What were you doing when it broke?
Pulling a box blade. Tried to lift it. No KTAC.
   / 3 point hitch broke #8
forgive me what is KTAC?
Also good luck with the repair, I hope your dealer supports you. That is not suppose to happen, but I know you know that.
   / 3 point hitch broke #9
What do you think made it brake?
   / 3 point hitch broke #10
3 years, should be under warrantee still , right?
GAS BUSTER FOR FLARE SYSTEM (A50854)
GAS BUSTER FOR...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
Komatsu PC138 (A50490)
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
