Jack32878
Hello, newb here with a question. Please forgive me if this has already been asked as I couldn't find anything to answer my question when I searched.
I have a BX25 and a County Line (TSC brand) 4' bush hog. I am cutting my field, about 6 acres, but my tractor keeps over heating. I have cut this field previously with this same tractor and cutter. I checked the tractor coolant, oil, hydro fluid, and gear oil in the cutter. All fluids are fine. The cutter blades look ok but could be a little dull. When I am cutting the field, grass is about 1 to 3 feet throuhout the field, the temp guage slowly creeps up. When it hits the temp threshold I just stop, stop the PTO and reduce the RPM down to about 2200. When I do this the engine seems to run fine and the collant flow will cool the engine down below the red area on the temp guage. Once it drops after 3-4 minutes I raise the RPM to about 2500-2600, start the PTO and take off. I might get 5-10 minutes before I start the process over. This time the grass is a little taller/thicker than last time so it may be an issue.
Any other ideas???
Any other ideas???
