lzicc
I'm looking into installing a third function remote on my L4060. I have allot of information on this from other post, but need to get a better idea how I would do this and how it would work.
To do this, I would need to tap into my FEL control valve. That is where I get a little lost on which hoses I tap into. I'm guessing I need to tap into the supply that goes to the FEL valve. Once I tap into that, I need another valve to operate the third function. The hoses that I tapped into would go to this new valve. Then I would run a set of hoses from the new valve to the front of the loader area with quick disconnects on them. Is that it? I hear allot about solenoids to do this. Where does this come into play or is this only used if using a diverter valve? I attached 2 pictures of the right side of my FEL. It looks like there are to plates that could take off to run the lines to the Third Function Remote through the FEL arms which would keep them protected.
