Ballast Box B8160 quick hitch compatible?
   / Ballast Box B8160 quick hitch compatible? #1
SLIMSHADIE
Central, IL
BX25D
As stated, is the ballast box B8160 compatible to a 3pt quick hitch? Anybody using this combination?
   / Ballast Box B8160 quick hitch compatible? #2
That design Kubota ballast box fit my BX2660 3 point in 2009. But now, on my B2620 with a Quick Hitch, I can not make it fit since the dimension is so narrow. Thus, I remove the QH when the ballast box is needed. If another attachment, such as the Box Blade etc. is mounted, I use them for ballast, unless working space or more ballast weight is a factor. Maybe some of the more capable TBN members can fabricate a solution.
Cheers,
Mike
   / Ballast Box B8160 quick hitch compatible? #3
It is NOT compatible. The L series ballast box does not work with a quick hitch either because of the way the top connection is made. I was able to use the quick hitch on the bottom pins but I use a chain on the top so that kind of defeats the purpose of the quick hitch but it works for me.
   / Ballast Box B8160 quick hitch compatible? #4
4shorts has a video where he modified one to be quick hitch compatible.
A separate subject, but I'm going to be making one that is QH compatible and uses a 55 gallon drum and a draw bar. The draw bar can be removed just in case I ever want to use it for something else.
   / Ballast Box B8160 quick hitch compatible? #5
No.
wrooster
   / Ballast Box B8160 quick hitch compatible? #6
In 2009 I had a set of "EZ Hitch" that had the same problem that the above PATS has. The company rep said that I could saw that top interference off, as it would then slip in there. Well that would defeat the usability of the EZ Hitch with other implements. So I just manually hooked up the box , since it was empty and not too heavy at that point. Now with the Quick Hitch I do the same thing, but have to take the QH off.....:thumbdown: Fortunately, that doesn't happen that often. Hope this helps.
Cheers,
Mike
   / Ballast Box B8160 quick hitch compatible? #7
I've bought 3 different sets of quick hitches. One was Pat's which I sold and two other different sets off e bay that were under $100 that I prefer. They don't have the "thing" sticking up and easy on and off. I even use one set upside down that comes down over the attachment pin and locks on.
   / Ballast Box B8160 quick hitch compatible? #8
Can you post which ones you like better. I'd like to get my dad a set, but would like a little cheaper...
   / Ballast Box B8160 quick hitch compatible? #10
2064 (A46502)
2064 (A46502)
2005 (A46502)
2005 (A46502)
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A46684)
2015 Ram 1500 4x4...
2007 PARK MONORAIL (A47001)
2007 PARK MONORAIL...
John Deere 455 Drill 30 ft (A48561)
John Deere 455...
Mack RD6885 Truck (A47369)
Mack RD6885 Truck...
