mainer0311
I bought my first tractor this fall to help with projects around my newly purchased house. The tractor is a 1981 B7100 with ~950 hours on it.
I use it to move split fire wood from my garage to my house. Wednesday morning I went about it as I normally do. Started it and tried to lift the counter weight (about 500lbs), it wouldn't move. I took the counter weight off and the 3 point still wouldn't go up. I could lift it by hand but it wouldn't stay up. Lifting it up slowly by hand and holding the lever in the lift position it feels as if it is ratcheting up under my power. At the top I let go and it falls back down.
The FEL works off of a different hyd pump and works as it should. Wednesday morning it was between 5° and 10° F. I pulled the dip stick on the transmission and it had plenty of very thick oil. I engaged the PTO and let it run at idle to try and warm up some of the oil with no help to the 3 point.
I attempted to lift the 3 point today at 25° F and it wouldn't move under hydraulic power.
The diverter valve is impossible to turn by hand and I didn't want to break something with a set of channel locks, I don't believe it is positioned incorrectly.
Any suggestions on where to check next? I've been meaning to do a full oil change but am waiting for warmer weather.
Cooper
Cooper
