rbargeron
Elite Member
Need some help with a neighbor's L225DT that makes gear noise in 4wd. Took off the side gearbox and found the idler gear inside the case is very loose on its shaft - it's center needle bearings are missing - likely disintegrated and in the bottom of the case. The gear is not broken but it's burnished from running with poor alignment.
Unfortunately the WSM doesn't cover the DT too well. So I'd like to find somebody with experience if possible. The parts are #67 thru #71 on the trans parts diagrams attached. The short shaft is located in the front of the differential case. If the tractor is separated at that joint, is the shaft accessible without taking the drive housings off? ? Anybody BTDT? Thanks, Dick B
