rtgt
Member
I have a Kubota B3200 with a LA504 FEL and pin-on bucket.
I am planning on adding a Grapple.
Landpride makes the SGC06 series Grapple that will pin on to my loader, but my first impression is that it isn't as strong as some of the root rake grapples out there. I believe that I would prefer the root rake style grapple.
Everything Attachments offers a 54" Construction Attachment Root Rake Grapple that can be made to pin-on to my FEL but it weights in at 455 pounds. At the pins I have about 1,000 pounds of lift.
Everything else I have found is either SSQA or JDQA.
SSQA adapters from ATI and WR Long fall between $800 & $900 and add an additional 75 to 100 pounds, and they move the grapple further out, lessening the capacity.
Another cost issue is converting my existing bucket to SSQA or buying another bucket.
I wouldn't mind staying with pin-on as it saves $, but I don't have very many pin-on grapple options that I am aware of.
One of the grapples I am considering is the EA 50 Compact Wicked Root Grapple and is about 275 pounds, but alas is not available in the B series pin-on.
Poking around I found that the new B series loaders, LA534 come with an SSQA option that appears to be like the JDQA. This got my brain housing group thinking.....
Will the LA534 SSQA option fit on a LA504?
Anyone with a LA534 that would mind confirming some measurements? Inside and outside distance between the mast pins and the distance between the mast pins and the cylinder pins should be all I need.
Second question to any LA534 owners - what is the distance from the center to the pin to the attachment face?
Just wondering if this is another SSQA solution.
