3-Point Hitch Hydraulic issues
   / Hydraulic issues #1
jamesft
WVA
2005 L39 tlb / MF1526 / M4900UT
Installed new rear 2 outlet hydraulics rear on MF 1526, can't get loader to work now, everything else works 3 pt hitch an new valve, loader just doesn't work, anyone have any ideas
   / Hydraulic issues #2
Did you do the work yourself?
   / Hydraulic issues #3
Explain exactly how you configured it. Post pics.
We can't help with just generalities.
   / Hydraulic issues #4
Where did you hook the remotes into?
Who did the work?
At any time, was the loader unhooked?
What dont work on the loader? A single function or everything? Nothing moves or just lacking speed/power?
Not gonna get anything helpful without more detail. And pictures always help.
   / Hydraulic issues
Ok, guys I am a little slow to react lol, I did do work myself, with useless instructions, remotes go into top of new valve then out back, loader kind of acts like it wants to work, but rollback or lift function doesn't work, went to dealer copied loader line hookup off new 1526 that had valve installed, all parts an lines seem to be installed same as mine, but no one at dealer had tried remotes to see if they work an no loader on it just 3 quick connect lines, I have a few pics I will post
   / Hydraulic issues
Here goes, removed loader lines manifold block from top right side of 3 pt hitch, discarded manifold, installed 3 studs in place of removed manifold block bolts, installed new manifold block on studs, installed new control valve + loader line plate ( separate piece) onto new manifold block with bolts thru loader line plate & control valve, removed 45 angle fitting from middle loader line, replaced with 90 ( other 2 were 90's already) installed 2- 90's in top of new valve, hooked up remote lines. Changed hydraulic filter & oil plus cleaned suction screen, bled hydraulic system by tractor manual. New valve seems to work, 3 ot hitch works without weight, no functions on loader work. That is where I left it an came to work for 3 weeks. Of course dealers want me to bring it in for 65 bucks an hr. I was trying to pickup some pointers from u guys to try when I get home. It's a new tractor practically 60 hrs purchased in May 2015
   / Hydraulic issues
image.jpgimage.jpgimage.jpgCH]
