PorkChopsMmm
Gold Member
From doing my searching here and on the internet at large it appears that the only two ways of getting quick attach pallet forks and I broke them out into pro's/con's below. Can you all confirm if I am correct? Maybe something new has come out recently? My main goal is to get pallet forks that attach to the tractor without the bucket to, to save weight, and to not have it cost a lot.
Kubota brand QA adapter PN# 1658
Pros: Adapter costs ~$250 and can use the existing bucket.
Cons: The pallet forks are more expensive than SSQA forks, supposedly are heavy, and you are limited to the attachments Kubota sells without customizing.
Kubota brand SSQA adapter PN# B2366
Pros: Any SSQA attachments can be used (if they are light weight enough) so attachments can be sourced for a cheaper price or easier to find on the used market.
Cons: Adapter costs ~$450 and cannot use the existing bucket -- need to weld bracket to existing bucket or buy new.
From what it looks like, even though the SSQA adapter allows a greater use of attachments I most likely won't use that many and the requirement to get some welding/fab work done to use a bucket greatly increases the cost and complexity.
It sounds like I would be better off buying the Kubota QA adapter and to try and source the Kubota branded forks for as cheap as possible.
Thoughts? Thanks in advance!
