First, make sure you get an SSQA skid-steer compatible interface loader. This day and age never buy one otherwise. Grapples, buckets, grapple buckets and a huge number of other things will fit. I recommend a grapple bucket (like the one on post#33 but lighter.) Neither a bucket alone nor a grapple alone. The bucket will be useful all the time and the grapple riding on it is a huge plus with limbs and posts and fallen trees, etc. whenever you may need it. Notice the activity in posts #8 and #25. To be honest, a B2650 is pretty light for large limbs, tree trunks and whole trees like that. For brush, debris and smaller limbs it should be great. It is easy to get into trouble lifting long heavy objects with a FEL. Being able to lift it in the first place may be the least of your troubles. Balance, tipping, tip over, etc. rapidly become issues. I use a tractor weighing around 9000 lbs with a 4-in-1 pinch bucket on the front that weighs 1000 lbs by itself all the time and, YES, it is all too easy pick up something that will tip you or make you wish you had not picked it up. I can't imagine doing a lot of that sort of work with a B2650 sized machine. Everything is relative though, just bite what you can chew.
