It is not mounted properly.
i think those clevis pins go into the slots behind the nose roller.
My B3200 had a similar deck.
Loosening the nuts will lower the mower. You might also need to adjust the back where it lifts the deck to have it lift higher.You guys are right as always Not sure why the dealer installed it that way.
I put it the way it should be and it lifts the front of the deck up weigh to high. I don't know if turning the nuts to make the link longer will have enough reach.
