robertm
I put my B2789 rear-mount blower on my BX this weekend to test and cut the driveshaft. I noticed that in the highest lift position, which I can't guarantee I won't reach when snow blowing, the lobe on the blower coupler at the tractor hits the lower link stabilizer brackets where attached to the plate below the PTO.
Has anyone had this issue? What can I do in regards to the shaft guard cup at the tractor PTO? It looks like the cup is too large, and is causing the plate where the stabilizers attach to ride up closer to the shaft. I always thought it best to leave the shaft guard, but on the BX with everything so tight and compact, I don't think standard implements always fit.
Any help is appreciated.
