So I chatted with the service guy on the phone on my way home. He said they had an extra cylinder & swapped it out & mentioned check valves as a possible fix for the sidelink leak down. Not an option as I explicitly got the float spools just for TnT as I loved on my L3200's toplink. Will worry about that next after things stop leaking externally. I assume they ordered a few when they ordered mine as I heard them mention that a while back & why else would I have not gotten it sooner if they had it on hand. Fired it up, ran it in & out a few times...
Sidelink fitting was still seeping a hair too. I unpluged the sidelink QDs & will check it in the morning. Will check to see if the bottom clevis is tweaked like the stock fixed ones are. I thought it was. The dealer says they will take care of me & so far they have. The lack of QA is kind of by whoever the manufacturer is, as well as the dealer is depressing though. Wouldn't suprise me one bit if those cylinders weren't OEM Kubota. I think FitRite will come up heavily in my conversation with them tomorrow. If that flies, it won't be a speedy fix, but at least I know they will be done right by somebody with pride in their work.
