I had always figured it was to allow a tighter turning radius, being that these are still "compact" tractors (at least theoretically), where better maneuverability is desired. With the front tires turned full lock, there is very little clearance between the FEL frame bracket and the front tires on most of the GL's. Putting wider or taller fronts on those models would require considerable re-engineering because you'd need to either stretch the wheelbase or change the FEL mounting design.
In the early days of TBN there was a long thread discussing the adventures of one GL owner who wanted to switch to some Michelin R4 radials because they had a much more aggressive lug design than the factory R4's (they were/are neat tires... R4 carcass with an R1 tread). In order to get the right front/rear mechanical ratio he ended up with a slightly larger than factory size of front tire, but had to slice off some of his FEL bracket so the tires didn't rub in a sharp turn.
Other than appearance (and I agree bigger tires would look better), would there be enough functional improvement from larger front tires to justify changing the design? How much more would you pay for it (because it would clearly add cost)?[/QUOTE
I don't believe it would cost anything beyond the tires themselves, maybe $50 difference. They put the larger tires on the less expensive MX machines. The MX5100 is the same size as the L5740, and even with the larger tires the MX turns a little tighter than the L5740, and the loaders on the two machines have the same lift capacity (within 50 lbs.) BUT- Your comment about the loader makes me wonder if the tire size is related to the ability to mount the cab on the GL series? I will look at the position of the loader mount and see if that might be it.
