Michael Aos
Gold Member
BX2370 | B2320 | BX2680 | B2601 | B2650 | |
Loader | LA243A | LA304 | LA344 | LA434 | LA534A |
500mm max height | 518 | 545 | 659 | 827 | |
pivot pin, max height | 745 | 772 | 948 | 1146 |
It's been great in that regard. Discovered a bunch of uses for it that I'd hadn't anticipated. Also realized some things are a lot heavier than I would have guessed. Weight matters.
Wishing it could lift more, I'd been glancing at specs and comparing the 518lb (500mm, max height) on the BX2370 -vs- 948lb (pivot pin, max height) on the B2601.
Got me thinking I could get nearly twice the lifting ability for not a lot more money. I finally wrote some numbers down so I could see things side-by-side.
Not as much difference as I thought.
