I have a B3030. Twice I have had the bolts loosen in the rear diff that hold the three point hitch on. The first time I missed the issue until it was too late. That meant an entire new rear cast aluminum piece and a 2000 grand bill for the repair. This time I have been trying to keep these bolts from coming loose but lately noticed new cracks in the cast casing of the rear diff again. I am sure my rear blading and roto tiller are causing this. Some of you who do not work your machine hard may not have this issue but for those who do here is my solution. I beefed up the back end draw bar and run 4x5 x1/4" angle to the frame to reinforce the 3 point hitch arm bracket. The original design only had one welded tab which broke and started all the movement. I added two bolts on each side and beefed up the whole assemble. It took me a while to figure it all out and two days to build it all. I'm confident now that the frame will take a lot of the load instead of the cast aluminum rear end.
