mrutkaus
- Joined
- Feb 1, 2004
- Messages
- 976
- Location
- 15 mi. N. of Winchester VA
- Tractor
- Kioti CK30HST, Kubota BX-1500,
I had cub cadets for 40 years with their belly belt mowers and I didn't care what I drove into/over, if the blade hit something, the belt slipped, whatever. Then, acquiring my BX1500 in my old age with its 48" mower I was set I thought. Set to break spindles unless I just had a level grass field to mow, that is.
After breaking two spindles in two months I was about to give up (why are the spindles almost first on the page at the dealers computer when they look for parts?). I had 'just' broken each side spindle hitting stumps and rocks, I don't know what I would have done if I'd broken the center, gearbox... truly given up.
I tried teflon washers on the blade bolts, nada, they just wouldn't keep the blades on.
I retighted all the blade bolts and looked carefully at the idler pulley spring. Hmmm it looks pretty hefty and keeps things pretty tight. Could I transform my Kubota into a Cub Cadet?
Enter Amazon 7" trampoline spring, $2.40 for 2: Amazon.com : 7 Inch Trampoline Spring Set of 1 : Trampoline Parts And Accessories : Patio, Lawn & Garden
This afternoon I barely got the old spring off (obviously remove that part of the cover first) I jused a spring puller tool and long screwdrivers etc. Installing the new spring was a breeze, it fit perfectly and was easy to put on.
Did a test mowing about half an acre of rough rollign grass with sticks rocks and weeds, worked so well I stopped often to look underneath. When I turned one blade by had the other two turned normally, but if I hald one blade and turned another, I could turn them independently. The belt was much looser on top. there was no unusual noise and no belt burning.
