Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2003
    Posts
    79
    Maine
    Kubota L-4310 GST/ 1979 Ford 1700
    Default 3 point hitch problems
    Why would my 3 point hitch not want to raise when I pull the lever? This has happened 3 or 4 times. I slide the lever back and forth several times, rev the tractor up, even shut it down and start it back up again, and nothing. Then it worked, note that this has only happened 3 or 4 times and on 2 different days. All other hydraulics worked fine. This is a L-4310, the hydraulic oil is full. Tractor has got only 210 hours. Anybody know what's going on?
  2. #2
    Super Member Henro's Avatar
    Join Date
    Jul 2003
    Posts
    5,412
    Few miles north of Pgh, PA
    Kubota B2910, BX2200...
    Default Re: 3 point hitch problems
    I have no idea but I would check the linkage to make sure there is not something loose and slipping.
    At some point the linkage probably turns a shaft going into the transmission housing. Maybe that point is slipping, or something else. Doesn't hurt to check anyway...good luck and here's hoping you find the solution easily!
  3. #3
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,563
    Texas
    Next time it does it, wiggle the FEL joystick a bit to make sure it's completely centered (i.e., valve closed), then see if your 3-point won't raise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
