Piston
Elite Member
You probably get more than enough snow to justify the FEL and power pack option I'm sure! However, you have the ideal tractor for a rear mount push behind blower.
The reason I say "ideal tractor" is because it's probably the only one I could imagine doing long drives with a rear push style blower.
Here me out....
If you were to bypass the safety switch on the seat so you could operate the tractor in reverse, and figure out a way to use the creep to position lever as speed control (I.e. Faster than a creep) then put a small electric over hydraulic motor on your steering rod, controlled by a joystick on your right side (facing backwards) then you'd have a very capable but compact bidirectional tractor.
The advantage of PTO power over hydraulic power is that you get much more power to the implement. Also, your pivot point is right over the rear tires so your tractor is considerably more maneuverable with a rear blower vs one sticking way out in front on the FEL.
Just an idea, but this is something I'd like to pursue if the day ever comes that I'm fortunate enough to own an M59/62.
A Pronovost TRC800 with rotating chute on the back of a tractor that you could face the direction your driving in would truly be impressive!
So basically this.....but spin the seat around and drive backwards.
Here me out....
