JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,773
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Wow. Quite a set of purchases ! Really nice.
I'm wanting to understand better the difference you have or expect to have between the "3rd function" on the loader and use of your remotes as hydraulic flow source for the front Lane Shark. My MF2660 may not be a good reference but it is what I have. My 4-in-1 bucket pinch function is run from one of my remotes. That same set of lines was used when I had a FEL-mounted very heavy brush cutter. I think I said before that when I moved my loader (curl or loader frame under force, not gravity) that stops the cutter motor very suddenly and then a very sudden hard runup to full speed again after I stopped moving the loader controls. Besides being awkward and uncomfortable I felt it would eventually result in damage. The hydraulic line pair with connectors mounted on my loader near the bucket was always referred to as the 3rd function so far as I know. Is there some other meaning ? Is there some magic by which the flow taken off the loader (rather than off a remote) changes the "one track mind" hydraulics? I don't see how it would unless there is a flow diverter valve built into your 3rd function flow source. I had heard that some larger Kubotas had factory options for complex hydraulic valving (?) By the way, my remotes seem to have a pretty large and direct return line to the sump.
Maybe you can explain/set me straight ?
