garf658
Member
- Joined
- Sep 24, 2008
- Messages
- 35
- Location
- Edmonton, Ab., Canada
- Tractor
- L5740HSTC, L3830-723FEL w/Curtis cab, IH 340U w/fel and the QA 3PH, Case 580K extendahoe
I was finishing up some rotary cutting for the day when I noticed a chattering noise while turning corners. Front wheels were not falling off so I decided to drive the tractor home immediately, and by the time I made it back 2 miles the drivetrain was slipping so badly I could only move in Mid range, low speed at 4 mph. When I tried high speed, it created a terrible grinding noise equivalent to shifting a vehicle without clutching. Made no difference in 2 or 4wd.
The clutch still works fine to engage the pto, so that seems ok. Once I reached the yard it seemed to work slightly better in reverse, probably because that side of the gears has not been chewed off yet.
It almost seems like a spline shaft has backed out, and is just barely making contact with the driven gear.
Tractor has 298 hrs, I envision thousand dollar bills floating away to the dealer next week. Any thoughts?
