Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Member Lopez69's Avatar
    Join Date
    Mar 2017
    Posts
    35
    Quebec
    Traded in b3350 waiting b26 with cab
    Default Kubota b26 wheel spacers
    Has anyone put spacers on their b26?? If so size please..
    I put laurin cab on my b26.and was thinking about wheel spacers..also I took bh off and put 64" blower on..which wasn't enough ballast for fel..also looking into ways to add more ballast to b26 with out taking blower off and adding ballast box..Kubota b26 wheel spacers-img_2432-jpgKubota b26 wheel spacers-img_2431-jpg
  2. #2
    Gold Member
    Join Date
    Aug 2015
    Posts
    265
    ɹǝpunuʍop
    Kubota B21TLB (B21, TL421, BT751) Toyota SDK4, T116 Bobcat
    Default Re: Kubota b26 wheel spacers
    Cab looks good, are your rear tires already ballasted?
  3. #3
    Join Date
    Mar 2017
    Posts
    35
    Quebec
    No I didn't want to fill tires..come summer bh goes back on..with cab/bh it's already heavy enough..would be waste of money for me to ballast my tires...
  4. #4
    Platinum Member AStanton's Avatar
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    If you ever plan to put chains on the rear wheels, you might not have enough clearance and will need spacers. I added kubota 1.5 " spacers to my B3030 for that reason.
  5. #5
    Join Date
    Mar 2017
    Posts
    35
    Quebec
    I was checking bro-tek they recommend 2"spacers for back and 1 1/2" for fronts..I'm not sure about chains just yet..most drive ways are flat and paved..am sure with ice underneath snow I'd wish for chains...was also thinking maybe them rubber chains...not quite sure yet..being first year with cab and snow blower on my b26.. I know loading tires isn't an option for me...but I do have to figure out how to add more ballast to rear with out removing snowblower...any ideas ?
  6. #6
    Platinum Member TMGT's Avatar
    Join Date
    Jul 2015
    Posts
    969
    Stafford, VA
    B2620
    Wheel weights
  7. #7
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    Quote Originally Posted by Lopez69 View Post
    Go through your first winter and see what works and doesn't work for you. Some winters are milder than others, so you still might not know what works or doesn't. I'm no mechanic, however, I wouldn't recommend ever putting spacers on the front wheels. At one point, I was so fed up with flat tires that I thought of foaming both the rear and the front wheels on my B3030. The dealer recommended against foaming the fronts due to added weight and stress on the front end.
  8. #8
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,954
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    How does the backhoe work with the cab. It doesn't look like that is possible unless you remove the entire back panel.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #9
    Join Date
    Mar 2017
    Posts
    35
    Quebec
    Backhoe works just as good with or with out cab..just a little tight to maneuver from front to back..but doable..I tend to leave door open when working cause I forget about cab and,broke hinges twice...glad glass door didn't break.....if anyone is thinking about and have the means to get a cab..laurin cab ..works great..you won't be disappointed...heat is great..option is ac..they put big box on top...was ugly ..so I opted out...windows onsides open...ohh..they have to remove your rops also.but laurin cab is osha approved as a rops.....just so you know.!!
  10. #10
    Member
    Join Date
    Apr 2011
    Posts
    41
    Elk Park NC
    Kubota B26TLB
    Nice looking cab, I'm envious of you on cold days however I'd be concerned about it being too restrictive the rest of the time. For snow removal I use a rear mount grading blade (250-300lbs) on my B26 with no additional weights or filled tires on a 1/3 mi. steep driveway. Everything is fine unless there's ice then its mandatory chains if I want to get back up to the top. For moving snow around I don't have any FEL issues, a full bucket of dirt could be a problem on anything but level ground. Your blower is probably closer to 400-500 lbs., you've got added weight of the cab (mostly over rear wheels) and you said you're on typically on level ground so other than chains for ice I wouldn't think you'd need to add anything else. I must admit I've been too cheap to buy chains yet (this is probably the year) but I'm pretty sure the R1's on the back have clearance for chains. I'm not where the tractor is currently so I'll have to check when I get back.
Similar Threads
  1. O&D Life on the help of wheel weights and wheel spacers
    By Tractor Dell in forum Kubota Owning/Operating
    Last Post: 09-15-2017, 09:38 PM
  2. Kubota GF1800 wheel spacers
    By swampfox4 in forum Customization
    Last Post: 06-07-2016, 10:11 PM
  3. Bro-Tek 2" Wheel Spacers for our B2920 Kubota
    By Howard92 in forum Kubota Owning/Operating
    Last Post: 01-06-2014, 03:25 PM
  4. Kubota B3030 Wheel Spacers
    By jweber03 in forum Parts/Repairs
    Last Post: 11-12-2012, 05:04 PM
  5. Traction GC Chains, Wheel Weights, Wheel Spacers
    By FDuce in forum Massey Ferguson Owning/Operating
    Last Post: 12-18-2010, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
