Tractor_Jim_CT
Hi everyone. About a month ago my FEL center hydraulic cylinder was leaking and with the help from the TractorByNet group, I removed the cylinder, had it repaired and re-installed it. The tractor was working well but the FEL and BH seemed slower than normal.
I stopped by my dealer and inquired about which kubota hydraulic fluid they used when they serviced my BX23 recenty and I bought a gallon. I figured with the past leaking cylinder issue I most likely lost a lot of fluid. When I checked today I noticed the stick was dry. I added about a gallon until it came to the top and I might have overfilled. The tractor seemed to be running well after I completed the fill, except I started seeing fluid on the ground in areas were I had been working. I looked under the tractor and there was a steady flow of hydraulic fluid sreaming down on the rear left side of the tractor. I lift the seat and crawled underneath and I can not tell where this fluid is coming from. I can hear a draining sound and not sure if anyone has had something like this has happen to anyone else. I added a picture to give members an idea of what I am seeing. I kept the tractor parked and it just continued streaming like in the picture. I think the FEL and BH still works but not sure. Any ideas on what this could be? Thank-you
