Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Join Date
    Sep 2016
    Posts
    60
    Ontario
    Kubota BX2370
    Default Coolant Leak from block heater? Kubota BX
    Bought my tractor new with the block heater installed. Noticed some coolant on the ground and traced it back to the block heater. Also noticed that my coolant level was very low. Glad I didn't overheat it.
    Now I either attempt to fix the leak myself or I have to rent a trailer to bring my tractor in (float charge to bring it in for warranty is insane!)
    Anyone have any suggestions on what the cause of the leak could be? I plan on taking a closer look at it when I get home from work.
    Thanks in advance!
  2. #2
    Platinum Member fishpick's Avatar
    Join Date
    May 2006
    Posts
    750
    The part of NY with high taxes
    L4760 & BX24
    Default Re: Coolant Leak from block heater? Kubota BX
    To install a block heater you knock out a freeze plug... I suppose if the knock out was miserable and someone beat the snot out of it with a screwdriver or something and gouged the block itself - the heater might not fit the hole tight enough where the ding is and it's leaking there.
  3. #3
    Platinum Member LouNY's Avatar
    Join Date
    Jul 2015
    Posts
    572
    Greenwich, NY
    Branson 8050, IH 574, Oliver 1550 Diesel Utility
    Some block heaters are threaded in, could just need some thread sealant, the ones that replace a frost plug usually have nut to snug them into place and swell the o ring that seals them
  4. #4
    Join Date
    Dec 2014
    Posts
    1,513
    Armstrong, British Columbia
    Kioti CK27, 580 SuperM Case Backhoe
    It's possible you can just tighten it a little to seal it .
  5. #5
    Veteran Member sandyc's Avatar
    Join Date
    Mar 2003
    Posts
    1,387
    Steep Falls, Maine
    Kubota B3350 HSDC
    Teflon tape for the threaded kind works. I installed a threaded thermostat in a 2200 a few years ago and had to redo it using tape. Threads on castings are not that tight
  6. #6
    Join Date
    Sep 2016
    Posts
    60
    Ontario
    Kubota BX2370
    This is actually what it looks like
    Coolant Leak from block heater? Kubota BX-maxresdefault-jpg
  7. #7
    Super Member oosik's Avatar
    Join Date
    Aug 2012
    Posts
    5,924
    AMBER, WA
    Kubota M6040
    I installed a block heater in one of my vehicles many years ago. It didn't take long and it started dripping. Then I found out that the threads in the engine block did not match the threads on the block heater. I got a plug with the correct threads - teflon pipe dope - sealed that hole up good and tight.
    Put in a lower heater hose heater - worked great.
    Ride hard or sit your butt on the porch
    "isn't it weird that in AMERICA, our flag & our culture offend so many people - but our benefits do not"
  8. #8
    Platinum Member Peter 315's Avatar
    Join Date
    Mar 2016
    Posts
    650
    NH
    Kubota L3800 hst kubota l47 tlb ( John deere 770 sold )
    If that's the correct heater it just taps into the freeze plug hole. Maybe the blocks gouged like somebody else said
  9. #9
    Gold Member massey driver's Avatar
    Join Date
    Aug 2009
    Posts
    449
    north of winnipeg canada
    massey 175,1655 BX 2370-1
    The block heater is a tap in.The part that looks like it has threads on does not go into the block the other side does.The instructions say to keep it from leaking you have to put Red locktite around the block heaterand hole in the block and tap it into the block.Of make sure everything is clean free from anitfreeze etc;.
    Massey Driver Larry
    MF 175 Diesel, BX 2370-1 Diesel,
    Still enjoy driving my tractors and making them work laughing:
  10. #10
    Join Date
    Apr 2013
    Posts
    170
    Central, IL
    BX25D
    Its a press fit block heater. Wondering if they used a sealant like Loctite 515 when installing heater. I installed mine a few years ago, pretty straight forward install. May have to unistall and install with sealant. There was a thread on here that a guy replaced his block heater. Made a slide hammer to get it off, pretty slick.
Similar Threads
  1. Block heater or in line coolant heater for my BX2230
    By joesco in forum Kubota Owning/Operating
    Last Post: 10-18-2017, 11:56 PM
  2. Engine block heater / coolant heater & high-capacity alternator
    By Phunge in forum John Deere Owning/Operating
    Last Post: 02-04-2015, 03:19 PM
  3. Replies: 4
    Last Post: 11-02-2012, 02:04 AM
  4. Engine block/coolant heater
    By getitdone1 in forum John Deere Owning/Operating
    Last Post: 01-09-2010, 05:59 PM
  5. Leak through freeze plug block heater
    By Colby Forest in forum Kubota Owning/Operating
    Last Post: 11-11-2009, 12:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
