Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    New Member
    Join Date
    Jul 2016
    Posts
    7
    Gravette
    Kubota L5030
    Default Re: 2004 Kubota HST L5030 knock and blue smoke
    Well, old girl is off to the dealer. I'll update on the diagnosis.
  2. #12
    Veteran Member FatTire's Avatar
    Join Date
    Oct 2007
    Posts
    1,211
    Colorado
    Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
    Good luck with her! Hope its not too expensive.
  3. #13
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    11,482
    Giddings, Texas
    JD 4310,JD5420
    Quote Originally Posted by Axlebender View Post
    Yes, please keep us posted. I am at a loss on this.
    One of these days....One of these days...
  4. #14
    New Member
    Join Date
    Jul 2016
    Posts
    7
    Gravette
    Kubota L5030
    Got the bad news last week. Apparently I knocked a plug out of the bottom of the radiator and lost my fluid. in about 200 yards engine got hot but didn't register with no fluid, so cracked head, which by itself is a little pricey, but also two cylinders damaged, so total engine replacement. They are quoting 10k out the door including taxes. Seems extraordinarily high, but maybe that's just what it is. 2004 L5030 HST 4 cylinder. having to decide if $10k engine replacement on a 14 year old tractor or new tractor with payments for 6 years. TRactor is in good shape overall, hydraulics are solid, good tires, HST is solid, with only 950 hours total. Leaning toward engine replacement as don't really want or need payments forever.
    What do you guys think?
  5. #15
    Super Member buckeyefarmer's Avatar
    Join Date
    Jun 2005
    Posts
    7,709
    MD
    Kubota L3940 L5030 MF205-4
    Id replace engine
    2010 - L3940HSTC, QA FEL, BH92
    2010 - Husqvarna YTH24V48LS (the other orange)
    2005 - L5030HST,QA,FEL
    198x - MF 205-4
    1990 - Wheelhorse 212H
    2017-ratchet rake, 2008-KK Tiller, 2006-Pallet forks, 2002-Carryall, 2000-PHD, 1999 - Trailer, 1999-6' rotary mower, 1999-cultivator, 1998-KK Finish Mower, 1998-Blade,1992 - Troybilt tiller, 2 wheel barrows, assorted gardening tools,
    http://www.tractorbynet.com/forums/r...life-farm.html
  6. #16
    Join Date
    Nov 2007
    Posts
    840
    PA
    Kubota L3130 HST 4x4 Kubota L4740-3 HST
    You might want to check what the price of a replacement engine costs. I’m guessing they are quoting $3-4K for labor.
    Splitting tractor you might consider replacing some wear items and seals while in there.
    Any chance the engine can be repaired versus buying replacement?
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  7. #17
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,961
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    I am buying a low hour used kubota engine for my BX2660 for $1500; lots cheaper than the Kubota dealership. You might do a bit of Internet surfing or even see if your dealership can get one. If all else fails, I would pay the price asked. That 5030 is a good little tractor that holds its value. Mine had 1400 hours and was sold before the dealer put it on the lot.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  8. #18
    Veteran Member JWR's Avatar
    Join Date
    Apr 2011
    Posts
    1,088
    So MD / WV
    MF 2660 LP, Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
    There are a lot of variables -- do you have a loader, is it a cab or open station, with remotes? and all sorts of things. I'd do quite a bit of shopping before plunking down $10K. That COULD still be the right answer but with that much $ involved it warrants some shopping.
    First, I'd shop around some on engine replacement costs. Surely someone offers "short block assemblies" just like they do for cars and trucks. A Supplier price on a short block gives you a good ref point. Most any full-fledged tractor repair shop could install a short block and would NOT have to be a kubota dealer. The labor of course will probably equal the price of the short block. Since you busted the head, a short bock MAY not come with a head (?)
    Secondly, I cannot tell where you live but it seems like Arkansas? There are several big salvage yards in Tenn and other parts of the South. I would call around and get a price on a complete used engine from a 5030. The worst they could do is not have any. I'd even try someone as far away as Wengers in Myerstown PA. It is not all that expensive to take a pickup up there if they had a good engine. They are first class, reliable people to deal with AND will probably give you excellent advice on the phone.
    Third, I'd go look at what used 5030's there are on the market (say using Tractor House website.) In a quick glance I see they have about 14 for sale. Wide variation of HOURS, whether it has a cab, loader, etc. At least I would look closely and absorb what is available & pros/cons at TractorHouse to put you in an informed state of mind. If your's is a cab model, everything works well like A/C, heater, etc. & the thing is in good shape, that might make a lot of difference leaning toward keeping the machine.
    There are several good Kubota dealers within a 2-3 hr drive from you if that is Gravette Ark. I'd definitely talk with 2 or 3 of them.
    Hopefully you are not against a wall time-wise and can take time to dig.
    At a wild long distance guess, I think the $10K and whatever you can get out of the disabled tractor will buy you a comparable replacement, BUT that is not a good deal unless it saves you $5 or $6K.
    I'd say "learn a lot by phone" before doing anything else. And good luck !
    jwr
    MF2660 LowProfile, 7', 5' and 4' BushHogs, Orsi Articulated boom hydraulic rotary cutter, Lane Shark FEL-mounted hyd cutter, Landpride 6' finish mower, Kubota BX2200, Two Kubota B2150's, 5' snowblower, 6' blade, scraper box, Gravely 1983 w/sulky, mower & snow blower, misc. attachments. Pequea 1018 deckover trailer, half interest in Massey Harris Pacer family heirloom... and a lot of junk...
  9. #19
    Join Date
    Jun 2005
    Posts
    7,709
    MD
    Quote Originally Posted by JWR View Post
    Agree, good reply. Do your homework.
    198x - MF 205-4
  10. #20
    Super Member dodge man's Avatar
    Join Date
    Oct 2008
    Posts
    5,314
    West central Illinois
    Kubota BX2350
    I'd personally fix it yourself. I think with that tractor you wouldn't have to split it and I'd find a used engine or a rebuilt one. I know on my BX I could have the engine out in a few hours but not sure about yours.
    Dave,
    BX2350
Similar Threads
  1. Dk50 HSt Blowing blue smoke
    By liberty2701 in forum Kioti Owning/Operating
    Last Post: 07-27-2014, 10:09 PM
  2. CK20 HST making knocking noise and blowing blue smoke
    By tassiedevil in forum Kioti Owning/Operating
    Last Post: 11-27-2010, 12:52 PM
  3. Kubota won't start & puffs blue smoke
    By rhamer in forum Parts/Repairs
    Last Post: 01-16-2010, 07:02 PM
  4. 2004 HST L5030 is a no go Kubo
    By flynlo21 in forum Kubota Owning/Operating
    Last Post: 11-13-2008, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
