Don716, When you had the 50 hour service done, the dealer did not change the hydro fluid? It is suspose to be apart of the 50 hour service. The filters are suspose to do as they are named, filter out contaminents in your oil/ hyd. fluid. The oil/ hyd. fluid does break down after a while along with any additives that are added to help with lubrication or stability of the fluids. My kubota 7610's manual states that all of the fluids are to be changen at 50 hours,that includes engine, trans., axles, hyd. fluid( hydrostat) Then at 100 hrs. I am to replace the engine oil and fuel filter. At 200 hrs. I am to replace the engine oil & filter, and fuel filter. At 300 hrs. I get to replace all of the filters and fluids in the tractor. My dealer was only charging $75.00 for the 50 hr. service to change everything so at that price I will let him do it. The only time I would change the filters out of the recomended hours is if I'm using the tractor in extreme environments, as in a gravel pit, coal yard, etc. If it is just around the yard type deal I would save the money UNLESS you are letting the tractor sit for long periods of time as in months without use. That will let moisture build up, and that will cause problems. Then you'll want to change the fluids along with the filters. Hope this helps. John
