The suction screen should be cleaned out with a non-flammable solvant at the first 50 hour service, then at every 300 hour service thereafter. If your model is a hydrostat, then you will have two filters to change on the transmission, a hydraulic filter on the right side and a much heavier filter on the left side for the hydrostat. Here is what should be required for a 50 hour service on a B7800
Change Engine Oil and Filter
Change Hydraulic and Hydrostat filters and oil
Clean out suction screen
Check air filter (replace if too dirty, not worth dusting a engine)
Retorque wheel lugnuts and or bolts (check with your service manual or just hit them with the impact /forums/images/graemlins/laugh.gif)
Check Clutch pedal freeplay (should be 20 to 30mm at top of pedal.)
Check front axle pivot adjustment.
Check starting and charging system (easy one)
Clean out Fuel/water separater bowl.
Lube tractor.
I think that's it. If you do these services yourself, then please take meticulous records, so your dealer won't deny warranty on you, due to lack of maintenance.
P.S. If you go buy a Workshop Manual for your B7800 it will show you how to do all of this stuff with pictures as well. They are worth their weight in gold.
Lube tractor.
