luvbug
Member
Has any body had a problem with their hydraulics locking up? The other day while doing some loader work I went to lower the FEL bucket and nothing happened, I moved the loader control around and still nothing. I ideled down and checked all the control levers to make sure I didn't knock anything in / out of gear and everything was O.K. I checked the 3PH control and it was all the way foward, PTO not engaged. I ran the rpm's back up and the loader went up but not down. I checked the BH and it started to extend, OK, but it would not contract. I ideled back down and shut down the tractor, checked the hyd. oil, OK, looked everything over, no problems anywhere noted. Started it back up and the problem still existed. Shut down again and I was able to lower everything thru the bleed down when moving the control levers. Started back up and parked it in the garage. Double checked everything again and again everything went up but not down. Two days later went to check on it and everything works fine???? Wierd??? Anybody else experience this? Called the dealer, he's picking it up in 5 days to check it out and do the 50hrs service. Any comments are appreciated.
