I have the same options on mine as well. My deflector actuator I got from a guy on eBay. It is a Kubota unit, but for a much larger snowblower, so it is larger and more robust. It has never had any water/ice problems.
I wired both drives into a small PVC junction box on the blower, and have a multi pin connector that plugs in when I attach the blower. In the junction box I installed a 5 amp self resetting circuit breaker (from Pep Boys) in each motor circuit. It protects the motors from damage if they are bottomed out. I have never had an issue with the rotate jamming after it bottomed out. You may want to look at the worm engagement to be sure everything looks okay.
paul
paul
