L-3130 LA723 FEL Needs Dental Work
   / L-3130 LA723 FEL Needs Dental Work #1
SkyPup
Elite Member
North Central, Florida
Kubota L-39 GST TLB, Kubota L3130GST, Massey 1030 HST, Kubota ZD-21 ProDecK, Two Euro VW TDIs
Busted off the solid steel center tooth off our L-3130 with the LA723 FEL toothbar while loading up a large oak trunk into the 72" bucket. It is amazing that the tooth could even be broken off like that, I would assume it would take at least a ton or double of pressure to do this. No harm was done to the bucket however.
   / L-3130 LA723 FEL Needs Dental Work #2
Bummer.
I suppose the way the teeth start off kind of flat could come in handy when trying to "scoop" something into the bucket, like a small log, but I always liked the beefier look of my ATI toothbar.
Did you find the tooth so you can weld it back on?
Haven't found the tooth yet, but still looking.
Incredible that I could snap off a 1 1/2" tooth bar with this powerful 'Bota.
   / L-3130 LA723 FEL Needs Dental Work #4
It would have been more incredible if the tooth hadn't broke and the rear wheels came off the ground /forums/images/graemlins/shocked.gif
/forums/images/graemlins/wink.gif
LOL, that is a possibility.
BTW, here is what the toothbar looked like brand new, or 550 hours ago....
   / L-3130 LA723 FEL Needs Dental Work #6
I've bent just the replaceable tooth on a number of mine. I have 340 hours on my L3830 but half as much paint on the inside of the bucket as yours. Yours looks pretty clean.
   / L-3130 LA723 FEL Needs Dental Work #7
Skypup,
A little off topic - but what do you do with all that wood?
Foghorn
We split it (all Live Oak) with our Northern Tools log splitter (30 tons with 5" hydraulic ram and 13HP honda) for use in our Vermont Castings Defiant woodstove as that is our only source of heat throught the winter. The stove heats 3,500+ sq. ft.
BTW, the toothbar had 550 hours of hard work on it prior to breaking the steel shank.
   / L-3130 LA723 FEL Needs Dental Work #9
Nice cathedral.
/forums/images/graemlins/smile.gif
   / L-3130 LA723 FEL Needs Dental Work #10
That is nice; thanks for the picture. Foghorn
