Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Sep 2004
    Posts
    203
    Connecticut
    BX23
    Default BX23 - Box Scrapers
    Was wondering what exactly can you use a box scraper for and what can't you do with it. What do they roughly cost?
    Anyone's experience.
    Are they like a tiller except not as deep..how deep do they go.
    Is there a model/size recommended for the BX23
    Thanks [img]/forums/images/graemlins/confused.gif[/img]
    BX23 - 17 hours
  2. #2
    Veteran Member theboman's Avatar
    Join Date
    Jun 2001
    Posts
    1,567
    Grayson, KY
    Kubota B7500 HST
    Default Re: BX23 - Box Scrapers
    A poor man's bull dozer!
    Level, move, dig. A box will do it all. If you have a FEL it's a wonderful counter weight.
    You can drill postholes with a box, or at least mine won't.
    Costs $300 and up. Depending on the brand, size.
    With a BX a 48" is the ticket.
    You'll find thousands of posts on box blades/box scrapers on TBN.
  3. #3
    Platinum Member Av8r3400's Avatar
    Join Date
    Jan 2005
    Posts
    684
    North Central Wisconsin
    Kubota L3400DT
    Go for the 48" King Kutter Box Blade! Cost me about $250. I use if for everything from gravel leveling to snow removal to balast! Picture of KK on a BX 2230
  4. #4
    SCB
    SCB is offline
    Join Date
    Oct 2003
    Posts
    556
    wa
    bx 23
    Here is a pic of a 48 inch box scraper on my bx. It is my most used implement. You can see that with the toothbar on the fel and the box on the back, you can clear and level pretty easily.
    Attached Images Attached Images
  5. #5
    Join Date
    Sep 2004
    Posts
    203
    Connecticut
    BX23
    How in the HXXX did you get that big stump out..I have a stump that's 1/10 the size, completely dug around..and I gave up on it.
    Did you use the pickup?
  6. #6
    Silver Member RichT's Avatar
    Join Date
    Jun 2003
    Posts
    218
    SOCAL
    Kubota B26
    I use a Gannon rollover scraper on my 22. Gives you a push, pull, and tooth option. Very versatile, but very expensive. I use it primarily to maintain my horse arena.
  7. #7
    SCB
    SCB is offline
    Join Date
    Oct 2003
    Posts
    556
    wa
    bx 23
    Jim,
    I had to break it into peices. I had a winch on one leg, tractor on another, and a truck on the third. I would put tension on all three and let it sit overnight. You could hear it creak. Next day I would put on more tension and so on. It took 3 days and it finally split into three and then the tractor could handle(barely) pulling it out of the hole . I had cut a ramp down into it to help in pulling the peices out. It was one that the trackhoe couldn't get becouse of logistics other wise I wouldn't have done it. the trackhoe I used took about 30 seconds to remove a few that size that I had. let's see... 30 seconds on the trackhoe versus 10 days on my BX hmmm...
    I did get alot of seat time on the backhoe though [img]/forums/images/graemlins/grin.gif[/img]
  8. #8
    SCB
    SCB is offline
    Join Date
    Oct 2003
    Posts
    556
    wa
    bx 23
    Rich,
    Thats a nice setup. Looks like it would be alot quicked than a boxblade.
  9. #9
    Join Date
    Jun 2003
    Posts
    218
    SOCAL
    Kubota B26
    Steve, actually it was originally designed for my JD332 cat0 tractor. I liked it so much that I kept it when I sold the JD and added some outboard eyelets to fit the BX cat1 lift arms - you can see them in the earlier pic. It fits perfect. I'm using it presently to excavate for a 25'x36' barn foundation/slab. Attached another pic of the rollover mounted on the BX early in the excavation. I cut the area with the teeth, then use the "in" blade to move the dirt.
  10. #10
    Join Date
    Sep 2004
    Posts
    61
    NW AR, USA
    Kubota L5030 HST
    Tractor Jim, I have a Bush Hog RBX720. I rented a few others and they worked fine. Mine was pretty expensive but I love it. If there is any way you can afford it, find one that has a scarer lift from the tractor seat. Getting off the tractor to raise and lower teeth gets old REAL fast. It depends on what you are doing but when they are used for scraping / leveling, scraping some more, etc. you'll want to retract the scarers.
    If you are rich, they have hydraulic lifts which seem nice. The manual handle will work fine.
    Here's a link to Bush Hog brand and the RBX:
    Bush Hog
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
