Results 1 to 6 of 6
03-03-2005, 08:39 PM #1
- Join Date
- Dec 2004
- Posts
- 61
- Location
- Minnesota
Kubota B7610 Rear outlets
Some photos of the rear hyd outlets on the B7610 if it works. I'm not sure how to attach photos.
03-03-2005, 08:48 PM #2
- Join Date
- Dec 2004
- Posts
- 61
- Location
- Minnesota
Re: Kubota B7610 Rear outlets
Photo #2
03-03-2005, 08:50 PM #3
- Join Date
- Dec 2004
- Posts
- 61
- Location
- Minnesota
The whole tractor.
03-03-2005, 09:19 PM #4
- Join Date
- Dec 2004
- Posts
- 61
- Location
- Minnesota
It appears to have worked? The outlets use prince SV series stack valve with power beyond. Plumed from the front 4 way to the SV and then back to the tractor. Not hard once I figured out where to put the valve. I did have help mounting it and fitting the hose. Originally I intended to put it outside the rops horizontally but then decided on the vertical mounting. The levers are not as handy as I would like but it works out ok. I did have to modifi the levers a bit. The bottom spool is a detent valve I intend for hyd motor use I have not yet decided weather or not to modifi that lever. Used pioneer 8010 couplers so I could interchange with ag tractors. Worked out good and it will see alot of use. I have a little trim work to do with it yet and some paint. Thanks Madreferee for all the help.
03-04-2005, 07:33 AM #5Elite Member
Rest in Peace
- Join Date
- Apr 2003
- Posts
- 3,741
- Location
- New Hampshire
- Tractor
- Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
You are welcome. Nice job.
03-04-2005, 07:45 AM #6
Suess,
Looks nice. Any chance you could post some LARGER pics?
Thanks,
Killer B 7610
