TOOLBOX FOR BX2230
   / TOOLBOX FOR BX2230 #1
lstumper067
North Mississippi / Nash Ridge
Kubota BX2230/Ramrod mini skid loader/Carlton stump cutter
Took an empty ammo can (4"X11") and mounted it to the rop. The two bolts that hold the slow moving triangle worked perfect....does not restrict arm movement but does make a good arm rest if you turn to your left side......a little....
stumper
Well, picutres will show the rest...
another
   / TOOLBOX FOR BX2230 #4
Looks good, any trouble with smacking your elbow ?
Steven
I don't think I will have that problem, I have short arms but it might be a possibility for a very long armed person...
stumper
one more picture
   / TOOLBOX FOR BX2230 #7
Looks industrial.
On of the things I like about the amobox solution is that the toolbox is actively closed. That is, it will not pop open even of you tip the tractor. Some other toolbox solutions would produce a shower of heavy metal tools (or sharp garden tools) that might cause more hurt than actually tipping the tractor would -- assuming you had the ROPs up and the seatbelt on.
Cliff
   / TOOLBOX FOR BX2230 #8
hey, what happened to the rear cover on the small turn-signal light? :)
I don't know, I think it just fell off somewhere...got to replace it soon
you are very observant...
stumper
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
KUBOTA M900 TRACTOR (A59823)
KUBOTA M900...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
