JWE
I purchased a 25 gallon FIMCO pull behind sprayer to use with my BX2200. If any other TBNers have this combination, I have a couple of questions.
Can you power the sprayer via the power connectors under the seat? I cannot find any specs on how much current the pump draws. I suspect the pump is less than 100 watts.
Because the sprayer has a short tongue you can't make a very sharp turn. The lower arms of the 3PH will not clear the sprayer tank. I could remove the links between the upper and lower arms and tie up the lower arms or I could make an extender for the drawbar. How did you resolve this problem?
John
John
