The only thing I can say is that I bought the L39 for the improved hydraulics and I've been impressed. Attached is a picture I took today hauling a cube of brick which weighs something like 2300 lbs.
Notice as well that it is way extended beyond were the normal bucket would be putting even more strain on the hydraulics. Even so I could roll it back no problem. Hope you find the source of your probelm because what you've been describing is not right.
To answer some of your other questions.
No problem lifting the front end of the ground.
Lifting a full cube of block off of a flatbed trailer it just couldn't lift it until I took off a row. Having said that I don't recall lifting the back end off the ground. I haven't tried just one corner. I was not expecting to be able to lift a full cube of block when I bought it as a cube is something like 3300 lbs which is way more than rated capacity again hanging way out there.
Tim
Tim
