Can someone help me understand the theory of the LA402 hydraulic valve. I see two hoses coming from the tractor hydraulic block, one out and one into the hydraulic block. The other hose to the tractor in the rear to the hydraulic tank. Why do you need 2 hoses from the tractor block? It would seem that you get pump pressure from both holes in the hydraulic block as fluid passes thru the block to the rear area of the tractor at all times. How could one be in, and the other out? The book says one side of the hydraulic block is out and one is in. What does the LA402 valve do with the fluid it receives? Does it send it back to the hydraulic block or back to the rear tank in the tractor? thanks in advance.
