ericbx1500
Gold Member
The first day I used the tractor (bx 1500) I lowered the deck and the lever went back to neutral position automactily, when I raised it did the same thing i know this normal. The next day I did some mowing worked fine. Today I lower the deck and the lever wont go back to neutral position by itself /forums/images/graemlins/confused.gif But when I raise it it goes back. So I poke around and notice the rod has spring assit in both directions. I noticed the spring on the inboard side was not helping move it back to neutral. The locknut(bolt) slipped down the shaft against the hairpin. must never had been tight from the factory. So I re-adjusted it after a couple of tries. Works great now /forums/images/graemlins/grin.gif first time I had it to tight popped back to neutral before deck dropped all the way. SEE ATTACHMENT
