I took delivery of the bagger for my BX2200 - 54" deck last week and put it together this weekend. I was getting all ready to write a big long story about how it went together and how it works, etc... however I have a problem.
The bagger attaches to the 3pt lift arms, but you need to take off the arms that connect the lift arms to the 3pt hydro actuator arms (OK, my terms are probably wrong, but I bet y'all know what I mean). In this mode the 3pt lift arms act as sort of a pivot that you can rock forward on and connect an extension arm from the bagger to the top of the top link. You actually remove the top link and slide the bagger extension through the ears and pin it.
Problem is when I rock the thing forward the extension piece comes up about 1.5" too short and I can't pin it. I've go the lift arms as wide as they'll go and even used some thin lynch pins to push the lift arms to the farthest extent of the lift pins. This makes the lift arms as "short as possible".
Any ideas? anyone else out there with a bagger with this problem. I'm sure someone will want pictures, and if I can find the time I'll snap some, but until then the description is all I have.
And yes, when I get the thing working I'll do a writeup with pictures and all.
-- Rock
-- Rock
