Results 1 to 2 of 2
  1. #1
    Join Date
    Apr 2000
    Posts
    1
    Default mower decks
    I own a kubota G1900 Garden Tractor with a 60" deck. This deck cuts very nicely but it tends to bounce alot while mowing due to being a Floating type mower. There are caster wheels on the back and anti scalp wheels on the front. Will the bouncing wear out the mowerdeck driveshaft or is this the way it is designed to operate? I had a suspended mower on my last tractor, could someone explain further. Thanks
  2. #2
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Re: mower decks
    Also have a G1900S with same deck,if your deck has the helper springs located on the back edge of mower,adjust these springs as tight as you can,without regard to what the chart shows.This will help your deck "float" a little better over a not so perfect lawn.Also,play with the tire pressure a little,the lower pressure will help the over-all ride of the mower quite a bit.Hope this helps,good luck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
