Kubota OEM Front Weight Bracket
   / Kubota OEM Front Weight Bracket #1
FRAN3
Member
CT
Kubota BX23
Does anyone own, or have you seem a photo of, the Factory supplied Front Weight Bracket & Suitcase Weights for the BX23?
I have plowed snow this winter with the BH on, which is great for rear wheel traction, but it makes the front a bit light traction and steering wise.
Also, I am interested in what the factory Sun Shade looks like and just how expensive it could be.
Before you ask, I get more information and help from TBN then I do from my dealer!
   / Kubota OEM Front Weight Bracket #2
FRAN3,
Regarding the sun shade, I purchased an aftermarket shade over the summer. Works great, no sun on the bald head anymore! The price was $235 delivered. The frame was strong enough to hold the lights.
   / Kubota OEM Front Weight Bracket #3
another photo
FirstBota,
Thanks for the photo's and a couple of questions.
First, is it easy to remove the Sun Shade from the brackets as I have to tilt my ROPS back to drive into my garage.
Second who is the manufacturer and/or where did you purchase it.
Thanks in advance.
   / Kubota OEM Front Weight Bracket #5
I have the OEM weight bracket and some suitcase weights from another manufacturer (cheaper). I believe the weights are 40lb each, and I have three. Can't imagine needing more than that. Helps a lot when pulling a BB (w/o FEL) or when using my aerator. Cannot use the OEM grill guard in conjunction with the weight bracket. No, I no longer remember the cost as it has been 4-5 years now.
Did this help?
Thanks ToolDad,
It does help as I was also interested in what might not work in conjunction with the Front Weight Bracket and I was especially interested if the Front Weight Bracket would fit with the Front Mount for the Plow, which I am now guessing that it will not.
It is beginning to look like time to take out the welder and start designing !
   / Kubota OEM Front Weight Bracket #7
</font><font color="blue" class="small">( FirstBota,
Thanks in advance. )</font>
FRAN3,
The sun shade isn't easily removable. However, I don't think it would be too difficult to make it removable. At a price of $235 it might be too close to the price of the tufftop? The name of the company was Sun Guard and their address is www.sun-guard.com. I actually purchased the sun shade on the bay.
   / Kubota OEM Front Weight Bracket #8
I have a BX2200 and researched this very thing about front weight bracket and weights.
The factory front weight bracket was about $92.00 last time I checked, designed to hold up to five 55lb. weights from Kubota.
I actually looked into having one made and the bracket would cost as much to have made as it would to purchase it outright. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Thanks Tom,
I appreciate the info !
   / Kubota OEM Front Weight Bracket #10
You are very welcome Fran!
I think bracket and weights are well over $300.00 from Kubota. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2 Row Custom Produce Cultivator (A52128)
2 Row Custom...
